Replacement for dual diaphram Bryant 225
cmwoodyatt
Member Posts: 1
in Plumbing
Hello all, I am looking for a replacement gas valve. The elecro-magnet no longer works. Im not versed in boilers but have some plumbing knowledge. I live in the northeast and its getting to be that time of year. Can anyone point me in the correct direction
Call a pro. Gas is not a DIY job. Try the Find a Contractor page of this site, here:
https://heatinghelp.com/find-a-contractor/All Steamed Up, Inc.
Consulting0 -
Manufactured gas?
It can be replaced with a modern combination valve but it needs to be adjusted by someone who knows how to do combustion analysis.0 -
Are you sure the coil is bad? is it a 24vac system or a millivolt system? if millivolt are you sure the thermopile isn't just worn out?0
- 50 Industry Classes
