Replacement for dual diaphram Bryant 225
cmwoodyatt
cmwoodyatt Member Posts: 1
Hello all,
I am looking for a replacement gas valve. The elecro-magnet no longer works. Im not versed in boilers but have some plumbing knowledge. I live in the northeast and its getting to be that time of year. Can anyone point me in the correct direction
    Steamhead Member Posts: 18,625
    edited October 2021
    Call a pro. Gas is not a DIY job. Try the Find a Contractor page of this site, here:
    https://heatinghelp.com/find-a-contractor/
    Consulting
    mattmia2 Member Posts: 17,204
    Manufactured gas?
    It can be replaced with a modern combination valve but it needs to be adjusted by someone who knows how to do combustion analysis.
    Are you sure the coil is bad? is it a 24vac system or a millivolt system? if millivolt are you sure the thermopile isn't just worn out?
