Weil McLain 1013-200
IowaSac
IowaSac Member Posts: 2
edited October 2021 in THE MAIN WALL
Starting it up today. Power on fine, all looks fine. Cycles through a few times and after a few failed cycles the pilot light indicator blinks. Try to see what I need to do for the auto pilot light and just can’t figure it out.. any ideas? Calling my professional tomorrow but likely very backed up and I believe it’s  simple issues. Any help?
  • Derheatmeister
    Derheatmeister Member Posts: 1,658
    What manufacturer are we talking about ?
    Just throwing a code on this site is very confusing to all...
    Make, Model Helps.
  • IowaSac
    Sorry that is the model number of the Weil Mccain boilers.
    EBEBRATT-Ed Member Posts: 18,257
    @IowaSac
    Look around for the model # those # don't sound right
    mattmia2 Member Posts: 13,557
    Pictures and model numbers of the ignition control and the gas valve and pilot assembly will tell us more.
  • Tim_D
    Tim_D Member Posts: 131
    Looks like you are installing a GV90? Gas pressures? Did you burp the gas line?
