Weil McLain 1013-200
IowaSac
Member Posts: 2
Starting it up today. Power on fine, all looks fine. Cycles through a few times and after a few failed cycles the pilot light indicator blinks. Try to see what I need to do for the auto pilot light and just can’t figure it out.. any ideas? Calling my professional tomorrow but likely very backed up and I believe it’s simple issues. Any help?
What manufacturer are we talking about ?
Just throwing a code on this site is very confusing to all...
Make, Model Helps.0 -
Sorry that is the model number of the Weil Mccain boilers.0
Pictures and model numbers of the ignition control and the gas valve and pilot assembly will tell us more.0
Looks like you are installing a GV90? Gas pressures? Did you burp the gas line?0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
