Loud water running sound in baseboard heaters
LiliP
LiliP Member Posts: 8
edited October 2021 in THE MAIN WALL
Hello,
I live in a condo ,third floor, my heaters have very loud water running sound when the heat is on , it happens to every heater in every room and it’s not a tickling or banging noise ,it is just like water is flushing rough the pipes ,and there is no water leaking .I don’t have any valve on these heaters ,Please give me some ideas of how can I make the noise go away .Thank you .
    Jamie Hall Member Posts: 26,783
    More likely air in the baseboards. Is there a bleeder fitting on one end or the other? Could try that...
    Or it could be just high velocity... and since you are in a condo with probably no access to the boiler room at all, can't do much about that.
    LiliP
  • LiliP
    The heaters all work good ,they are hot.
  • neilc
    neilc Member Posts: 3,111
    so what Jamie was saying,
    do you have your own boiler and basement?
    or is the boiler behind a locked door controlled by ???
    there's air in there with the hot water,
    either because the static pressure is too low, or a poor piping job around the boiler, or ???
    can you get to the boiler? and post pictures?
    picture of the pressure gage also,
    known to beat dead horses
    LiliP
  • LiliP
    edited October 2021
    The boiler is controlled by the HOA and I don’t have access to it .
    the sound is like when toilets flushing ,water just keeps coming and going …
    I found this at the pipe end .not sure if it’s a bleeder.
  • LiliP
    EBEBRATT-Ed Member Posts: 19,452
    @LiliP
    Yes that's the bleeder. Call maintenance and have them check the water pressure in the boiler and have them bleed the baseboard
    LiliP
  • LiliP
    I released all the air from the pipes by bleeding ,but the water running sound is still happening :(
    mattmia2 Member Posts: 15,427
    Did air come out?
  • LiliP
    Yeah, air came out ,I stopped bleeding till water came out.
    HVACNUT Member Posts: 7,198
    edited October 2021
    Does every unit have their own boiler?
    If your unit shares a boiler with other units then the whole system needs to be bled, not just your unit.
    The feed valve could also be closed and you made the problem worse.
    Call for maintenance.
