Some Updates Today
I would turn the safety valve away from the top of the boiler and install a drop leg toward the floor with a pail to catch any drips or release from the safety valve.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron1 -
Are you saying it's not allowed or that you don't see it?STEAM DOCTOR said:No black pipe on pressure relief valve outlet
Some inspectors don't like black pipe on safety valve drips, since it can rust up.STEVEusaPA said:
Consulting2 -
Steamhead said:
Also if there is a threaded end on that black pipe some one who does not know what they are doing will see a drip and think that a cap would be the perfect solution....STEVEusaPA said:
Some inspectors don't like black pipe on safety valve drips, since it can rust up.STEAM DOCTOR said:No black pipe on pressure relief valve outlet
Years ago my dad was an expert witness for a case where a boiler exploded and destroyed an entire (thankfully unoccupied at the time) wing of a nursing home. They took him to the site and while walking around he actually found the relief valve with the discharge piping capped off. Upon questioning the maintenance guy said he saw it dripping on Friday afternoon and decided to just cap it off until he could replace it on Monday. As Steamhead always says.....1 -
All together now.....................delta T said:Also if there is a threaded end on that black pipe some one who does not know what they are doing will see a drip and think that a cap would be the perfect solution....
Years ago my dad was an expert witness for a case where a boiler exploded and destroyed an entire (thankfully unoccupied at the time) wing of a nursing home. They took him to the site and while walking around he actually found the relief valve with the discharge piping capped off. Upon questioning the maintenance guy said he saw it dripping on Friday afternoon and decided to just cap it off until he could replace it on Monday. As Steamhead always says.....All Steamed Up, Inc.
Consulting2
