ICP furnace not working
lammel01
Member Posts: 3
I have ICP furnace that is current not working when heating is requested.
I am looking for help on if there is 120 V going from control board to gas valve. Gas valve is not passing on the 120V to inducer motor. Due to which it is not starting.
I have tested inducer motor by isolating it and it operates fine.
Any idea if there is something wrong with gas valve.
Here is what the circuit looks like0
Do not "test" the gas valve with 120v.
The gas valve is 24v only.
The board doesn't have diagnostics?
Try turning off the power for 5 minutes with the thermostat turned down below room temperature. Turn power back on and raise the thermostat. See what the furnace does and look for a code.
If the inducer isn't even starting, then the board doesn't know there's a call for heat or it's in lockout.0 -
I would highly recommend that you get a qualified tech to repair this.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
