Hydro level VXT water feeder
gkimmeo
Member Posts: 7
Can the VXT be installed using PEX tubing?
I wouldn't connect PEX directly to the a boiler, but if the feed is into a wet return, why not? Sure.Br. Jamie, osb
It doesn't have mounting brackets that I am aware of, so you will need to figure out a way to support it. PEX directly to it wouldn't be my first choice. Perhaps a length of copper on either side to provide some stable mounting and then switch to PEX.1
- 50 Industry Classes
