Hartford loop
pipers
Member Posts: 21
Why do we use a close nipple out of the tee on the Hartford loop
You want the least amount of pressure drop. Some old drawings actually use a Y fitting instead of a tee.
Wye takeoff down to the wet returns?EdTheHeaterMan said:You want the least amount of pressure drop. Some old drawings actually use a Y fitting instead of a tee.
@pipers
In a Hartford loop you have condensate coming up a vertical return, crossing over the close nipple and going back down into the boiler. The equalizer on top has steam in it. The water and steam meet in the Hartford loop. A short (close) nipple or a Y fitting provides the shortest horizontal pipe which reduces banging and noise. If you use a longer nipple you could get a lot of banging1
- 50 Industry Classes
