Boiler opinion wanted: Laars Mini-Therm
JohnNY
JohnNY Member Posts: 3,334
Hello all,
I'm soliciting opinions on this Laars Mini-Therm boiler. I like the idea of having my guys easily carry 200,000 BTUs down rickety old Brooklyn cellar steps rather than risk injury with a 500-pound piece of cast iron as they have for decades.
https://s3.amazonaws.com/s3.supplyhouse.com/product_files/Laars-JX200NLIU1-Brochure.pdf
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
  • JUGHNE
    JUGHNE Member Posts: 11,508
    One would think they would have included the shipping weights in the spec sheet.
    Certainly less than standard CI.
    EBEBRATT-Ed Member Posts: 19,310
    Flow I think is the key to keeping them happy. Primary Secondary. They get a lot of use in pool heaters etc.
    I bet @Alan (California Radiant) Forbes see's a lot of these
    Alan (California Radiant) ForbesJohnNY
  • jad3675
    jad3675 Member Posts: 127
    supplyhouse.com has the weight listed on the product page - the 100K unit is 145lbs.
    John
    JUGHNE
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,681
    What Ed said about proper flow rate. They work best on primary/secondary. Year ago, I did some work for them. I asked their engineers if they ever considered making a steam boiler. He said they had one now. "All you have to do is use the wrong pump," he said.
    Pipe it right (as I know you will) and I think you'll like these a lot. And your point about the rickety Brooklyn stairs would sure be my convincer.
    Retired and loving it.
    hot_rod Member Posts: 26,391
    I would add that they like a consistent load as they are usually a fixed output. Some models had two stage gas valves.
    On a multi zoned system, especially with micro zones a buffer may be desired.
    They need boiler return protection if used on low temperature radiant.
    Hard to beat copper as a heat exchange material, these have a long proven history and are fairly bulletproof even in abused installations :) These and other copper tube brands were the go to in the early radiant days.
  • Agree with all the above. I service about 200 or more of them here in the Bay Area; their JVS Mini-Therms were very popular in the 80's and 90's and are still going strong; almost indestructible. They will soot up when they serve radiant unprotected, so 1°-2° piping is in order.
  • BigRob
    BigRob Member Posts: 332
    The delta T pump across the low loss header is cool. The literature mentions adjustable water temperature and outdoor reset. I guess the control PWM's the gas valve?
  • JohnNY
    Thanks, Dan. Every time we lug a cast iron hot water boiler into a house I shake my head and wonder how long we're going to do this for.
    Classes
