Boiler opinion wanted: Laars Mini-Therm
JohnNY
Member Posts: 3,324
Hello all,
I'm soliciting opinions on this Laars Mini-Therm boiler. I like the idea of having my guys easily carry 200,000 BTUs down rickety old Brooklyn cellar steps rather than risk injury with a 500-pound piece of cast iron as they have for decades.
https://s3.amazonaws.com/s3.supplyhouse.com/product_files/Laars-JX200NLIU1-Brochure.pdf
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
One would think they would have included the shipping weights in the spec sheet.
Certainly less than standard CI.0 -
Flow I think is the key to keeping them happy. Primary Secondary. They get a lot of use in pool heaters etc.
I bet @Alan (California Radiant) Forbes see's a lot of these2 -
What Ed said about proper flow rate. They work best on primary/secondary. Year ago, I did some work for them. I asked their engineers if they ever considered making a steam boiler. He said they had one now. "All you have to do is use the wrong pump," he said.
Pipe it right (as I know you will) and I think you'll like these a lot. And your point about the rickety Brooklyn stairs would sure be my convincer.Retired and loving it.0 -
I would add that they like a consistent load as they are usually a fixed output. Some models had two stage gas valves.
On a multi zoned system, especially with micro zones a buffer may be desired.
They need boiler return protection if used on low temperature radiant.
Hard to beat copper as a heat exchange material, these have a long proven history and are fairly bulletproof even in abused installationsThese and other copper tube brands were the go to in the early radiant days.
Agree with all the above. I service about 200 or more of them here in the Bay Area; their JVS Mini-Therms were very popular in the 80's and 90's and are still going strong; almost indestructible. They will soot up when they serve radiant unprotected, so 1°-2° piping is in order.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
The delta T pump across the low loss header is cool. The literature mentions adjustable water temperature and outdoor reset. I guess the control PWM's the gas valve?0
Thanks, Dan. Every time we lug a cast iron hot water boiler into a house I shake my head and wonder how long we're going to do this for.DanHolohan said:
Pipe it right (as I know you will) and I think you'll like these a lot. And your point about the rickety Brooklyn stairs would sure be my convincer.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
