Creepy Crawl Spaces
HeatingHelp
Administrator Posts: 638
Creepy Crawl Spaces
October, being the month for ghosts and goblins, seems like the perfect time to reminisce about those tight spots few want to visit, but many must. It’s just the nature of the business, and what could be spookier than a dank, dark crawl space?
My benchmark is installing the first central (hydronic) heating systems in old New England Colonials. At best you have 1-1/2 feet of crawl space and maybe a dug potato cellar under a kitchen floor door to gain access. BTW - those Army Trenching Shovels can work fairly well in crawl spaces.
Generations of critters having established domicile via loose stone foundations is only the beginning.
These homes were well, if seemingly crudely built by current standards. Have you ever tried to drill baseboard piping holes through a 200+ old American Chestnut Post & Beam Frame? It's the northern equivalent to Lignum Vitae. Smoking drills and a half-barrel of sweat to follow.
Sweet(?) Memories .....0 -
> "Daddy long legs .... one of the most poisonous spiders there are but their teeth are too short to bite humans."
FWIW: this is not true. One bit Adam Savage but the venom is weak to humans. They do eat deadly redback spiders, but by throwing webbing from a distance. They have never harmed humans.
https://en.wikipedia.org/wiki/Pholcidae
Just don't look at them, not up close. Ugh!0 -
Wow, just reading those accounts gave me flashbacks to some of my own crawl space adventures. YIKES Glad I'm retired!0
I have watched Utubes from AntiDIY in SC (or is it NC).
He has some interesting repairs.
Almost everything is either attic or crawlspace.
Either area usually has ample room for working and install.
In one of his shows, as he goes into the crawl space, he is greeted by a casket on blocks, being stored there. The calm guy he usually is, he just says "well we won't open that thing".
Maybe a common practice in the SE....IDK.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
