Is it possible
slaneri
Member Posts: 3
To take the bleeder valve sout so we can clean behind them
does water have to be shut off
is it just a hex nut to take off then
push cooper pipe in toward s center
does anyone sell original round knobs to cover the stem
they are almost all broken
thanks
Originally they had wooden knobs . Back in the day expansion tanks were open to the system and bleeding the radiators or convectors was a normal pass time . You would need to drop system pressure tp replace .. I would recommend manual peanut bleeders .
You can find plastic knobs. Yes you will have to drain the radiator. The back plate may be nailed to the wall.
There are 10 upstairs and 10 downstairs , can I turn pressure off
( water off) and do one at a time or one after the other all at once
before heating season
which is like next week
in Meaford Ontario
thanks
doug0 -
The peanut valve sounds good
it’s a rental and I don’t want people
playing with them
there are 2 wooden knobs on two of them0 -
Take the pressure off the boiler, then open all the bleeders and let the rads drain.
That's quite a project to just clean behind them.
Maybe replace the bleeders or at least have some extras on hand.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
