Boiler IOM needed
DaveB1972
DaveB1972 Member Posts: 10
Gents,
I have a customer who just bought a house and the original manuals are not present. I have searched the Dunkirk site including the obsolete archive to no avail.
The boiler is a MN: PS-41 and I cannot find anything on it.
I’m suspecting the exhaust setup is wrong for this furnace. I think someone made a box draft hood and installed it after the 90 at the top of the stack before it goes to the chimney. It’s slow to get a decent draft (that is to completely pull all exhaust gasses out) if it ever does. It also has no blocked flue switches. Before I make any changes I’d like to see what the manufacturer spec’d but with no manual…..
anyone have a IOM for it?
    EBEBRATT-Ed Member Posts: 20,160
    Just call Dunkirk
    Steamhead Member Posts: 18,480
    Post some pics.
    Also, the draft problem may be an issue with the chimney rather than the boiler.
    Consulting
    EdTheHeaterMan Member Posts: 12,142
    I think the PS means it is a steam boiler. 41 is probably a 4 section boiler. Does your boiler look like this?
    ...maybe without the vent damper?
