Re-pipe my boiler?
crobar
Member Posts: 4
I have a Weil-Mclain 140k btu gas boiler with cast iron radiators. My expansion tank (Fill-trol style) needs replacing. It currently sits on the floor horizontally and I was wondering if I should just replace it as is or move it and go with a standard tank and a new fill valve set-up. If I move it, where should it go? I also don't have an air separator so I'm guessing I should add that as well if I start changing the configuration. Thanks for any advice.
- 117 Geothermal
