What do these boiler numbers mean?
mmc239
Member Posts: 94
What do these numbers mean?0
It's a gas fired steam boiler. Maximum and minimum inlet gas pressures are shown. Boiler manifold pressure (pressure at the burner is shown.
The boiler will burn 231,000 btus of natural gas.
The boiler will heat 591 square feet of installed radiation.
It's powered by 120 volts
It has an automatic vent damper0 -
Just for clarification - the 591 square feet of installed radiation mentioned above refers to the capacity of the radiators, it has nothing to do with the floor area of the home.0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
