What's Inside?
HeatingHelp
Administrator Posts: 637
What's Inside?
This is always a great question to ask when you’re troubleshooting. You won't believe the things we've found inside heating systems that cause all sorts of mechanical mayhem.
Animals in the works!
I've had squirrels clogging flues, raccoons in chimneys, bats in the boiler and, worse then the rest, a nest of bold-faced hornets in the flue cap on a boiler that was off all summer!0 -
Yikes!Retired and loving it.0
Outstanding heating stories, especially strategically placing that riser support to allow for proper expansion.0
Thanks!Retired and loving it.0
I have had this happen twice now, so the second time troubleshooting it was easier. I shut the valves off to a Rinnai water heater to fix a leaking pipe, and when I turned them back on, I could not get flow out of the hot water line. I thought I might have got some debris in the filter, so i took it off and made sure it was clean. It was starting to get to me, until I remembered the last time I had an issue like this. I realized I was getting flow into the heater , but not out, so I took the outlet valve apart and found that although the valve turns, and has resistance, it would not move the ball inside. The dang shaft sheared off inside! I just bypassed the valve, and it is working fine now. Now I just have to get back over there with a replacement valve.
Rick
Years ago I was installing my own lav faucet in the master bath.
It was a fairly high end, all brass, center set, 8" spacings with levers.
To confirm in/out and left/right etc, I would blow thru the inlet open the valve to determine passages. One was fine the other would not pass air.
The port was never drilled at the factory.
Called the company and the lady assured me that all products were tested for leaks at the factory. I had to explain that it would never leak and also never pass water.
They did send a new one out at no charge.
Glad I never installed it to find out it was not drilled thru.1
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
