Steam Locomotive Explosion NTSB Investigation
If anyone is interested in some not-that-light reading, this was an interesting read. It concerns a locomotive explosion that happened in 1995 and includes an in-depth assessment of the causes behind the explosion. It’s interesting to see a modern safety review of something so old.
It reminded me of some of the steam history in Dan’s book so I thought I’d share. Enjoy!
Homeowner from Providence, RI
Home b. 1897, one-pipe steam with a indirect gravity hot air system using Gold's pin radiators.
  • leonz
    leonz Member Posts: 1,793
    edited September 2021
    Nothing like a lack of maintenance for a coal stoker fired steam locomotive and no useable operation training to ruin a locomotive that did not see much "required" maintenance.
  • retiredguy
    retiredguy Member Posts: 1,086
    When you are dealing with a hand fired coal fired boiler there is no low water cut off or pressure controls. Your safety devices are usually just a high/low water whistle and a visual water level device we call a "sight glass" or "sight tube", and for over-pressure, Steam safety valves. That is it. So when you are firing a boiler of this design, you need to be fully aware of your job and surroundings. I always hated hand fired coal boilers since you always had to be ready for any problem. Good maintenance is paramount.
    Jamie Hall Member Posts: 27,036
    The same sorts of problems -- with a few others, such as what do you do with a solid fuel boiler which has a fire in it and no place to dump the heat -- appear with all solid fuel boilers. At least with a steam locomotive on coal you can dump the fire on the tracks if the water gets low and you can't put any in! I have an uneasy suspicion that we may see more boiler explosions in smaller and residential settings as solid fuel boilers become more popular but are installed with inadequate safety mechanisms.
  • retiredguy
    On a few jobs, I had to open the fire doors and pull the burning coal out onto the floor to get rid of the heat.
