Above subfloor pex routed in 3/4" plywood
WillC
Member Posts: 37
Hi,
When your subfloor is already 3/4" of plywood and you want to use another layer of 3/4" of plywood and route the tubing, what's the best way to attach this plywood without being an headache when it is time to use the router? Would you glue it too?
The first layer of plywood is tongue and grove, is it safe to go with some regular plywood for the second layer?
Is the second (top) layer the finished floor? If not, what is?
Check out the Viega Climate Panel..0
May i ask why 3/4" Plywood and Tubing was used ?joeinmo said:I used 1 1/2" screws to attach my 8" strips of 3/4" plywood to a 3/4" plywood subfloor. I spaced the 8" strips 3/4" apart to lay down pex. Using a router seems too labor intensive instead of just ripping the plywood in 8" strips and screwing them down using a spacer block as you go.
Does the Install have a 16" tubing spacing ?
Or does it have 8" Tubing spacing which is very hard to accieve with 3/4"0 -
He never said 3/4" tube, he said 3/4" between the sleepers- which is perfect for 1/2" tube- which is perfect for 8" spacing.Derheatmeister said:
- 50 Industry Classes
