HePex
Solar_Hog
Solar_Hog Member Posts: 2
edited August 2021 in THE MAIN WALL
I have a water furnace that also chills glycol. I noticed that hePex temperature rating only states the highest temperature it will tolerate. What is the cold end? The water furnace chills to about 30F
  • Ironman
    Ironman Member Posts: 7,903
    That shouldn't be an issue, but check the tubing manufacturer's specs.
    Bob Boan
    hot_rod Member Posts: 27,447
    What are you using 30F chilled fluid for? Seems awful cold for AC coils or radiant cooling?
