The coolest things to salvage
dobro23
Member Posts: 72
I seem to have an issue throwing things way. Constantly salvaging cool stuff on boiler replacement jobs. I have a collection of different radiator vents, coin vents, cool fittings etc. Some have been reused in Edison style/steampunk lamps that Ive built but mostly everything just lays around in milk crates. But the COOLEST THING IVE EVER FOUND AND WHAT I CONSIDER TO BE THE HOLY GRAIL OF STUFF YOU CAN COME ACROSS IS THIS! IN NEAR MINT CONDITION!!
1
Still made the last I knew but I could be wrong.
Yeah, I just checked. Mercoid is now owned by Dryer instruments. Those controls are still made and are quite pricey, maybe $700. Looks like they still make them with mercury switches or snap switches, at least that's what the catalog shows0 -
IIRC Dwyer owns Mercoid now.All Steamed Up, Inc.
Consulting1 -
Last I checked Dwyer Instruments still sells these Mercoid vacuum switches. A similar operating pressure switch is shown.
Given the choice, I'll take a Mercoid vacuum switch over a Square D diaphragm type. Nothing ever goes wrong with a Mercoid switch.
I see 50 year YO Mercoid switches working perfectly all the time. A Square D diaphragm type seems to need re-adjusting every year.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.1 -
Mercoids are good.
In the past we saw them occasionally on boilers for pressure controls some engineers used to spec them. They lasted forever I don't think i ever replaced a bad one.
You get what you pay for they were $$$$0 -
Fantastic find! I have one buried in my basement............somewhere. Becoming very rare.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
