Again, PVC pipe certified for use as venting material?
Code is the minimum. We as professionals are supposed to be better than minimum.Cost is what you spend , value is what you get.
cell # 413-841-6726
I'd be thrilled with the minimum from many.......Charlie from wmass said:Code is the minimum. We as professionals are supposed to be better than minimum.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I guess I’m a little slow; the homeowners I meet with can afford quite a bit, it seems. There’s millions of furnaces out there with pvc. I feel like the change is fine, I’m just not at the level you are with it0
- 120 Geothermal
