Again, PVC pipe certified for use as venting material?
2»
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Code is the minimum. We as professionals are supposed to be better than minimum.
    cell # 413-841-6726
  • ChrisJ
    ChrisJ Member Posts: 17,060
       I'd be thrilled with the minimum from many.......
  • GW
    GW Member Posts: 5,135
    I guess I’m a little slow; the homeowners I meet with can afford quite a bit, it seems. There’s millions of furnaces out there with pvc. I feel like the change is fine, I’m just not at the level you are with it
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
