Again, PVC pipe certified for use as venting material?
Code is the minimum. We as professionals are supposed to be better than minimum.Cost is what you spend , value is what you get.
cell # 413-841-6726
Charlie from wmass said:Code is the minimum. We as professionals are supposed to be better than minimum.
I guess I’m a little slow; the homeowners I meet with can afford quite a bit, it seems. There’s millions of furnaces out there with pvc. I feel like the change is fine, I’m just not at the level you are with it0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 392 Solar
- 55 Water Quality
- 46 Industry Classes
