Painting Steam Radiators
Joe Joyce
Member Posts: 4
Hi - I’m looking for advice on repainting my steam cast iron radiators, currently silver.
I read that silver is the worst color to use, but looking for advice. Thanks, Joe
Hi @Joejoyce , This might help! https://heatinghelp.com/systems-help-center/radiator-paint-colors/
Yours, Larry0 -
It's only the worst if the area served by that radiator is too cold. Usually it's the best because radiation is often too large for the heat loss of the room it's in (with the windows shut at least).
Silver paint will make a radiator radiate less, which is often a desired result (as I think the article that Larry linked discusses)
Of course, if you paint all your radiators silver (or partially cover them, etc, then that can exacerbate the problem of having the boiler be oversized....it's all a systemNJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 15.8K Strictly Steam
