Need parts for old baseboard heat system
Any idea where I could go to obtain these parts? I have no idea who may have manufactured the system. Hopefully the photos will help.
Thank you!
Hopefully someone here knows exactly what this is, but try looking at the various slant fin profiles.0
It does look like an early SlantFin product. They also offer nice aluminum upgrade covers.
https://www.slantfin.com/revital-line-series/Bob "hot rod" Rohr
Thank you both for your replies! I'll try reaching out to Slant/Fin to see if they are their products. Knowing the manufacturer may help with the search.hot_rod said:It does look like an early SlantFin product. They also offer nice aluminum upgrade covers.
https://www.slantfin.com/revital-line-series/0 -
I dont think you are going to have much luck. The closet I think you will come to that is Argo Low trim. Do the fins have a plastic strip running along the edges?
You could try ebay to see if anyone tearing some out put some of the trim up there.0
I checked with Slant/Fin and their reply was this was not their product. Thanks for the idea. At least I know what it is 'not'.hot_rod said:It does look like an early SlantFin product. They also offer nice aluminum upgrade covers.
Thanks for the idea, I checked the profiles of the Argo products and this does not match. I don't recall seeing any plastic under the trim.kcopp said:I dont think you are going to have much luck. The closet I think you will come to that is Argo Low trim. Do the fins have a plastic strip running along the edges?
Thanks. I'm trying every image search I can think of. Will try Ebay too.mattmia2 said:You could try ebay to see if anyone tearing some out put some of the trim up there.
Try craigslist0
Hi @g_ppetto , Have you considered using some sheet metal tools to make your own? A hand seamer and some snips just might do it.
Yours, Larry1 -
Those end caps may be a bit more challenging but those joints would be easy to make.
If you could make a piece that butts up against the wall at the ends and screws to the cover that would be easier to make than trying to close the end.0 -
I wonder if a handy woodworker could build caps and joint covers.
Hardwood finished to match your floor would make a pretty cool accent/statement.
One would need to leave room for a little expansion of the BB.
It might be the look of bumper guards on a car.0 -
Thank you all for your comments and suggestions!! They are really helpful.Larry Weingarten said:
Yours, Larry
I'm heading out today to pick up a couple of hand seamers and plan to see what I can do with some flashing that was replaced on the house. A few bends, some emery cloth and just maybe I can make some replacement parts. The baseboards are all going to get painted so I just have to be good enough to blend in...mattmia2 said:Those end caps may be a bit more challenging but those joints would be easy to make.
@JUGHNE - wood would be nice, but I do not know anyone that works with wood. Thanks for the suggestion.0 -
Wanted to follow up. I was able to fabricate some parts and pop them in place tonight. It's all getting painted so hopefully they will blend in. Thanks again to everyone that commented and offered suggestions. BTW, I did measure everything and worked up my own estimate to cover everything with Neatheat covers. They were the closest for the size. Neatheat components would have been about $1300. They did look good though... This was about $50 at Harbor Freight for some shears and two hand seamers, a piece of scrap, and some of my time. I'm happy with it.
Thanks again! Photo below...
Looking good!!
And now you've got more tools!
Yours, Larry0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 392 Solar
- 55 Water Quality
- 46 Industry Classes
