Gas fired boiler, oil in burner tubes
PMNightmare
Member Posts: 1
in Gas Heating
I'm working on a fairly old (2014ish) Buderus boiler doing preventative maintenance. I'm also fairly new to working on gas boilers as I've only had experience with steam boilers.
There are three large burner tubes that feed in to the combustion chamber that mysteriously started leaking some kind of green oil a couple days after cleaning them (no water or chemicals used in burner tubes, water used to flush tank). Nobody seems to know what the oil could be or where it's coming from. The oil has since stopped, but we are still trying to determine what it is and where it came from.
Anyone experience this before that could possibly clue me in on what it is?
Did you pull the cap off of the drip leg to see if it's clean and dry?
Glycol, maybe?0
Gas fired, Huh? Oil you say? Could be threading oil finally made its way out. If it was thread oil it is unusual to see it there. Usually that gets trapped in drip legs. If it was the threader, he probably sloped his pipe the wrong way while cutting. I have seen 3/4" * 7" drip legs full of oil before.1
Maybe it is from the outside utility. Could be worth taking off the drip leg and looking inside.0
Did it show up after re-firing the boiler?
If it came out of the gas offices (assuming this is an atmospheric burner), then it must have passed thru the gas valve.
It seems that any oil passing thru a gas valve could affect the 100% shut off ability of the valve, just like water.
IIWM, I would remove the gas valve, manifold and orifices to check for the oil gooey.0
- 15.8K Strictly Steam
