How many companies manufacture in the USA low temp hydronic wall panel heaters?
Steamback
Member Posts: 37
I want to do a thorough review of any and all hydronic wall panel heaters I can possibly get my hands on which absolutely MUST be made in the United States, not overseas. Can you help me out and share any companies which you know sell hydronic panel heaters made in the USA? Specifically I'm looking for a list of USA manufacturers who make and sell any hydronic panel heater optimized for low temperature water (ie 110-120F). Please, no fans. All passive options with natural convection and radiation only.
Runtal... made in Massachusetts. Only one I know of. They are $$$
https://runtalnorthamerica.com/wp-content/uploads/2020/07/ResidentialHydronicBrochure.pdf
3 -
I had no idea they were made in the states.kcopp said:Runtal... made in Massachusetts. Only one I know of. They are $$$
Awesome product!"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
AFAIK Runtal is the only one for low temp made in the US.0
Any type of radiation can be "low temp" if it is sized for lower water temps at the building's heat loss.All Steamed Up, Inc.
Consulting2 -
@Steamhead has the answer, any heat emitters or radiator can run at temperatures above room ambient and transfer heat. There is an ap available to de-rate sectional cast iron radiators running a wide range of SWT. Download Caleffi Idronics 25 for some examples.Bob "hot rod" Rohr
Living the hydronic dream1
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
