Baseboard Adventures
HeatingHelp
Administrator Posts: 717
Most houses have too much baseboard and that means that, if you size the new boiler to the actual heat loss of the house, the folks will be able to run that boiler at a lower temperature on most days.
Or a high-mass cast-iron boiler with delta-t distribution management.0
Excess baseboard also allows greater utilization of thermal storage tanks used with wood, wood pellet, and wood chip boilers. We have found that on average heating days, many homes heat just fine with baseboard supplied by 140-160 F water. Consequently, domestic water heating requirements often become the trigger for starting a boiler and bringing the thermal storage tanks back up to their upper temperature limit.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
