Hybrid fan coil/furnace
MeatBallZnGravY
Member Posts: 6
I'm wondering if any of you guys have ever installed a gas fired furnace with a radiant coil, so the radiant would be the primary heat and incase of boiler failure we could fire up furnace to heat home.
Basically replace Evap coil for radiant coil so to speak.
any insight would be helpful.
Cheers
Cheers
Your either mixing up some terms or not providing all the info.
Do you have a boiler to do the radiant, and a furnace with a radiant coil...or do you just have a furnace and a coil for the radiant?
The curiosity is healthy! However, what benefits would this provide? Why would the coil have priority? A high efficiency furnace is easier to get right compared to a high efficiency boiler because the return air temp is always low enough to condense, and standard boilers/furnace would be what and what. I think the gas furnace paired with AC/Heat pump is most common for a reason, you get redundancy, cooling, and higher efficiency.1
- 167 Indoor-Air Quality
