Grundfos Alpha stopped running with display flashing
Member Posts: 4,447
check installed? I've seen them do that when they are either being spun backwards or have flow when un-powered from another cir, for example.Bob "hot rod" Rohr
This was during a call for heat. The system was installed 10 years ago and it's just now acting up. (I didn't know the Alpa's have been around that long.)
Don't know about a check, but there seems to be gravity flow.
Odd that it would just now start if it was a mis-pipe. Maybe it fried form over-voltage or something. Try Osborne Sales the local rep for some answers.
Alphas are built in Fresno, maybe 15 years now? We are getting oldBob "hot rod" Rohr
Did you try to unpower it and repower it? leave it off for a few minutes.
This is a circuit board problem. I guess the polarity and voltage of the outlet that the pump is plugged into is correct.0 -
"Did you try to unpower it and repower it? leave it off for a few minutes."
Yes, kept on flashing.
I'm going there tomorrow and will let you know what I find.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Bring a new one. Been there,done that.To learn more about this professional, click here to visit their ad in Find A Contractor.0
Bet the shaft has gotten stuck and won't turn. That happened to us once.All Steamed Up, Inc.
Consulting1 -
I've never known you to be wrong.Steamhead said:Bet the shaft has gotten stuck and won't turn. That happened to us once.
Two btu per sq ft for degree difference for a slab1 -
I've never done this. I like to know why thing fail. I've taken apart many devices to understand the "why".
I would pry off the label and look for screws under the label that fasten the black electronic control to the pump housing. I would look at the control circuitry and look to see if it is plugged into the pump windings and that the control board is making good contact. Is anything looking burnt? Possibly a power surge.
I always plug the new boilers and ECM pumps into a computer grade surge protector.1 -
Смени този кондензатор 47mf/35v и е готова.
Was is ein Elko? (What is an Elko?)0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
