Grundfos Alpha stopped running with display flashing
Has anyone had this problem before?
https://youtu.be/eUSPyGb8Bu8
    hot_rod Member Posts: 26,467
    check installed? I've seen them do that when they are either being spun backwards or have flow when un-powered from another cir, for example.
    Alan (California Radiant) Forbes Member Posts: 4,624
    edited March 2020
    This was during a call for heat. The system was installed 10 years ago and it's just now acting up. (I didn't know the Alpa's have been around that long.)
    Don't know about a check, but there seems to be gravity flow.
    Odd that it would just now start if it was a mis-pipe. Maybe it fried form over-voltage or something. Try Osborne Sales the local rep for some answers.
    Alphas are built in Fresno, maybe 15 years now? We are getting old :(
  • HomerJSmith
    HomerJSmith Member Posts: 2,700
    edited March 2020
    Did you try to unpower it and repower it? leave it off for a few minutes.
    This is a circuit board problem. I guess the polarity and voltage of the outlet that the pump is plugged into is correct.
  • "Did you try to unpower it and repower it? leave it off for a few minutes."
    Yes, kept on flashing.
    I'm going there tomorrow and will let you know what I find.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    Bring a new one. Been there,done that.
    Steamhead Member Posts: 18,179
    Bet the shaft has gotten stuck and won't turn. That happened to us once.
    Consulting
    HomerJSmith
    I've never known you to be wrong. :D
    kcopp
  • We replaced the motor this morning. The old impeller spun freely. I think the electronics went bad.
    kcopp
  • HomerJSmith
    I've never done this. I like to know why thing fail. I've taken apart many devices to understand the "why".
    I would pry off the label and look for screws under the label that fasten the black electronic control to the pump housing. I would look at the control circuitry and look to see if it is plugged into the pump windings and that the control board is making good contact. Is anything looking burnt? Possibly a power surge.
    I always plug the new boilers and ECM pumps into a computer grade surge protector.
    kcopp
  • Petar
    Petar Member Posts: 2
    Смени този кондензатор 47mf/35v и е готова.
  • Petar
  • psb75
    psb75 Member Posts: 1,097
    Was is ein Elko? (What is an Elko?)
