Mitsubishi Mini-Split Outdoor Condenser Hissing when in heating mode
RomanGK_26986764589
Member Posts: 229
One of my outdoor units is making hissing sound which is heard near the compressor and the valves when the unit is in heating mode. The unit is Mitsubishi 30k BTU MXZ unit.
I've attached a short video depicting the sound:
https://www.youtube.com/watch?v=WZBSHY--pSk
Is this the reversing valve hissing when energized or something else? My other 2 outdoor 20k BTU units do not make this kind of hissing sound when in heating mode. The unit heats & cools just fine and makes no hissing sound when in cooling mode.
https://www.youtube.com/watch?v=WZBSHY--pSk Is this the reversing valve hissing when energized or something else? My other 2 outdoor 20k BTU units do not make this kind of hissing sound when in heating mode. The unit heats & cools just fine and makes no hissing sound when in cooling mode.
Bump. Anyone?0
@GW When it's in cooling mode. No hissing sounds of any kind.0
Ok so no matter what the output is? No matter if it’s one zone or both zones? Can you kinda tell where it’s coming from? Did you take the panels off at all? I’d have the rep come at look0
What's the outdoor temperature while your trying Heating mode?0
@GW No matter how many zones are running. I even posted a video above to depict that sound. It's where the compressor and the valves are. Only in heating mode. I am guessing it's the reversing valve hissing when energized? Do you know if the reversing valve is energized in heating or in cooling in Mitsubishi?0
@pecmsg When we use heating the temp outside is usually 45-55ish degree range.0
If that charge isn’t perfect 55* may be too high.0
I don’t know if it’s powered in heat or cool,. I changed a reversing valve on a 3c30Hyper last year- not a fun time. Quite the process, flowed nitrogen on every joint. almost a full day job to get it done and recharged
get the rep there
@pecmsg You mean if it could be overcharged or undercharged?0
Only way to tell tell is to pull it and weight it!RomanGK_26986764589 said:@pecmsg You mean if it could be overcharged or undercharged?0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
