Some Baseboards Heating - Others Not
broncosejr
broncosejr Member Posts: 15
I just recently moved into a new home and had my contractor install Nest Thermostats.
I turned on the heat for the first time and in some rooms, the baseboards are heating and in other rooms, they’re doing nothing at all.
Any thoughts on what could be causing this?
  • JUGHNE
    JUGHNE Member Posts: 11,549
    What does the contractor say about this?
    How many tstats do you have?
    Jamie Hall Member Posts: 27,373
    and what do the thermostats control?
