Boston Area Engineer - Residential
BostonGTR
Member Posts: 18
We recently purchased a brand new house based in MA (metrowest). We are having some "challenges" with the HVAC system (Bryant forced hot air) due to a very poor installation. The HVAC contractor has since been fired from the development. Rather than have an HVAC contractor come in and assess the system (and provide a quote to fix the deficiencies), I was hoping to get a recommendation for an engineer who could provide an independent review/evaluation of the system, along with a remedial action plan. This would hopefully provide me with some leverage with the builder. Let me know if you need any additional information. Any input would be greatly appreciated. Thanks.
I lived in a scorched air home for 30 years.
The HVAC system was a builders special.
After many attempts to resolve the condition I came up with a solution that improved our comfort.
A temporary fix for you is to set the fan run at least 10 minutes longer after the heat and cooling cycle turns off. This will allow for a little better circulation of of heated or cooled in each cycle.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Challenges with brand new buildings is very common actually .
https://drive.google.com/file/d/11JWPk4bPBf1TXmhTpnhvD8ffnmX7SsiU/view
http://energysmartohio.com/how_it_works/building-science-101/You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
Thanks for the lead on TE2 Engineering; I'll reach out to them.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
