Rad valve oomph
GW
GW Member Posts: 5,177
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
luketheplumber
    Steamhead Member Posts: 18,393
    Looks like you need to eat your spinach >:)
    Consulting
    GWluketheplumber
  • STEVEusaPA
    What about the piping underneath the floor?
    mattmia2CLamb
  • GW
    I figured the cast joints in the basement would hold to allow  the valve to break free. Valve didn’t seem like brass though, kinda steely looking. Hence the big oomph
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • dopey27177
    dopey27177 Member Posts: 916
    Do You Know that when in doubt about brass and iron a simple magnet will tell you whats up.
    A hack saw or Sawzall sometimes work better than a wrench.
    Jake
    GW
  • retiredguy
    retiredguy Member Posts: 1,086
    It is always a wise idea to carry a set of extra long wrench handles. That said, I would use a back-up wrench to protect the piping under the floor.
    GWAlan (California Radiant) Forbes
  • BobC
    BobC Member Posts: 5,555
    A number of years ago I wanted to replace the anode rod in my gas HWH. I got the 1-1/16' socket and a 24" breaker bar and nothing, they must buy special impact wrenches with infinite torque to use at the factory. A buddy came over and he bear hugged the tank and still nothing, we are both north of 220 pounds and have been doing 16 oz curls for a long time..
    I had a couple of steel vacuum wands (over 4 ft coupled) in my infinite pile of junk so I put those on that 2 ft breaker bar and finally broke it free but I also spun the tank and my buddy a bit. Those metal vacuum wands are a lot stronger than they look. We got that rod out and spun the tank back so the piping was happy
    3PSI gauge
    GWLarry Weingarten
  • JUGHNE
    JUGHNE Member Posts: 11,545
    edited May 2021
    I struggled to remove a nipple from a CI **** tee I wanted to reuse.
    It came loose with a "ping" and later found the tee had been cracked.
    Could not see the crack until installing the new nipple. :'(
    Note: how about that auto censoring.....the tee had 3 different sizes.....thus the father was unknown. :)
    GW
    mattmia2 Member Posts: 16,404
    they aren't that tight from the factory, they corrode in place over time. Adding some teflon tape and dope when thy are new will help a lot.
  • BobC
    That tank is 13 years old now, I'll try and remember to put tape and dope on the new tank when the time comes.
    Bob
    3PSI gauge
