radiant floor heat transfer plates
Hi,
You can cut those plate if you want to accommodate length. I prefer to cover as much area as possible with plates for even heating. I used miter saw with carbide blade to cut those plates. Plates made with t aluminum will cut with that very easily.
Yes you have to remove nails. you can follow my topic and you will get lots of information from that discussion. Lots of pro commented and guided me through out my project and I am so much thankful to them after having best feel of the heating my house in last winter.
https://forum.heatinghelp.com/discussion/179216/need-advise-confirmation-for-underfloor-between-joist-radiant-installation-northern-nj-zone-5/p1Thank you,
Hiren Patel0 -
If you hate the nails and do not want to crawl around in a Crawl space , make Swiss Cheese out of your Joists you may consider a flooring system such as Viega Climate Panel, It only adds a 1/2" height to the floor, has a better heat transfer and is much easier to install..
https://www.viega.us/en/products/Catalog/Heating-and-Cooling-Systems/Heating-and-Cooling-Solutions/Panels-Plates-Tracks-and-Mats/Viega-Climate-Panel-2810-2US.html
Whenever I go to cut a plate, cut it in half only. Adjust with the spacing from end to end to make it so. However with that being said 8-10" would be the max.
Remember, no plates on the ends of the joist cavity, about 8-10" again, you always want the pex to exit the end of the plate, not the middle
Dave H.Dave Holdorf
Taco, Inc
Dave any specific reason for the tube exiting at the end of the plate?Dave H_2 said:Whenever I go to cut a plate, cut it in half only. Adjust with the spacing from end to end to make it so. However with that being said 8-10" would be the max.
Dave H.Thank you,
Hiren Patel0 -
Pex will expand and contract as it heats up and cools down not radially but linearly. It will become longer and shorter. If you exit a plate in the middle, it can eventually work its way out of the plate and then just be hanging there. At the end of the joists, that is where a wall typically is above. If you feet are in that area walking, that means you are using the wall to hold you up and at that point, a warm floor is not your priority!
The floor may be a degree or two cooler in those area but still going to heat the space.
Dave Holdorf
Taco, Inc
As Dave mentioned it most likely will work...However the Delta T will be more that just a degree or two.Dave H_2 said:Pex will expand and contract as it heats up and cools down not radially but linearly. It will become longer and shorter. If you exit a plate in the middle, it can eventually work its way out of the plate and then just be hanging there. At the end of the joists, that is where a wall typically is above. If you feet are in that area walking, that means you are using the wall to hold you up and at that point, a warm floor is not your priority!
Here is a Link to some Infrared camera images of different "Plates"
https://radiantdesignandsupply.com/theheatexchanger/2013/3/4/comparative-infra-red-study-of-heat-transfer-plates
Make sure that you drill a Large enough hole and that the tube is installed so that it does not rub on the floor joist,otherwise you may have noises every time the heat comes on...
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
