Tankless water heater distance to dryer vent?
lumbee77
Member Posts: 5
Hi, Do you have a copy of the installation instructions for the water heater? I’d start there.
Yours, Larry0 -
Yes, I looked through the installation manual and only saw an item that said “avoid termination locations near a dryer vent”. I assume the avoidance is not code requirements but because dryer lint can dirty the burners if sucked into the combustion air intake (we’ve seen that cause issues with our tankless heater). I’d love to move the tankless vents away from the dryer but it’s a finished basement and being at the current corner there isn’t space to move left or right much at all.0
Hi, My experience is that code enforcement folks want you to follow manufacturer's instructions. Basically, the installation instructions become code. Others here will have thoughts on it! It wouldn't be pretty, but it seems the dryer vent could be run on the outside of the wall some feet to the left, so it isn't close to the water heater intake.
Yours, Larry0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
