Wet return rotten where it meets copper
mjgordon
Member Posts: 16
Single radiator branch's 3/4" wet return from a small addition built in the 50s. I realize copper to black pipe is not ideal, but it's been running this way for at least 15 years probably 30+. I replaced a similar junction a few years ago at the rear of this picture. The new problem is in the foreground. As soon as heating season is over in a few weeks here in NJ I thought I'd heat up then nearby union and replace the rotten nipple. Can you use a dielectric joint/union here like you would on a hot water heater? Other recommendations? Otherwise I guess I'll just replace the rotten Piece with black pipe nipple and wait until it rots in a decade.
That's got to be like the number one failure point for any steam system so don't blame the nipple too much, it did its job. I'd say Schedule 80 steel or brass like said above. Looks like most of the corrosion there happened after it started leaking.
Te nipple installed in the sweat T should have been brass. Brass tied into a cast iron nipple is less likely to corrode.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Is that tee copper or brass?
Looks like the threads weren't sealed and were leaking a little.0 -
The T can be copper or brass. Use the existing T and save the extra work.
Agreed that this is probably the number one failure point (at least in my findings). Any thoughts on why that nipple fails more often then other male threads on the wet return?ethicalpaul said:That's got to be like the number one failure point for any steam system so don't blame the nipple too much, it did its job. I'd say Schedule 80 steel or brass like said above. Looks like most of the corrosion there happened after it started leaking.0
