Navien combi boiler NCB- 250/150H
waldemar kawalko
Member Posts: 14
Will Navien combi boiler NCB- 250/150H support 2500sqf heating 6 hot water radiators and DHW for 3 baths and 3 kitches total 6 people in Brooklyn NY townhouse ?
tankless Navien NFB 301C with indirect water heater 35gal will make it work ?0
what tankless condesing boiler are you suggesting ?0
We had dozens of Naviens are my last company out in the field over the last 4 years. Never had a single issue or changed any parts. Except one in a commercial setting that wasn’t maintained. Needed HE flushed and flow sensor pulled and cleaned. Mostly combi.
Just installed a NHB-150 on a former gravity system with an indirect. Customer couldn’t be happier. It replaced a 1 year old Noritz COmbi that was poorly installed and giving them nothing but trouble.
Ironically I reinstalled that used Noritz in my house (have other primary heating sources) and its been fine going on 2 months now. Go figure.1 -
seems like boiler tankless condensing boiler with indirect is way to go now question is sizing and brand0
ibc has different setup diagrams which help to figure out my needs and existing conditions0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
