TT PS 60 E-02
Rich Davis_2
Member Posts: 121
Been having trouble with my boiler lighting. Didn't have any trouble when the temp outside was cold, now that it's warming up when there is a call for heat most times it won't light. When I push resent it will light 1st or 2nd try and runs fine time it' satisfied and there is another call for heat. When the system was always hot in cold wether no problem but now that the systems only needs to be warm, problems. Checked the inginator, replaced a year ago, it looks OK. Any suggestions, Thanks
Most likely is the igniter or flame sensor. When was it serviced last?
It's just like a car needs a tune up and a combustion test to be reliable0 -
I serviced it last fall before heating season0
Insufficient information. Make and model, I assume it's a Triangle Tube, PS 60 with an error code E-02? (Failed ignition after 5 attempts) You can try unplugging and re-plugging the module and any safety devices in the low voltage circuit. Check the programing, warm weather cutout, if equipped with ODR. Condensate draining ok? Check the gap on the igniter and make sure it is securely screwed to the boiler plate.
Could it be a problem with your thermostat?
You might want to get a combustion analysis with a Tech with a recently calibrated CO meter more so if it has never been done.0 -
HS DUU TITWKC GWTP Da!HomerJSmith said:Insufficient information. Make and model...
...Could it be a problem with your thermostat? ...
Translation = @HomerJSmith, Don't U understand? This Is The Way Kids Communicate. Get With The Program. Dah!
1
- 167 Indoor-Air Quality
