Pilot Light issue
Back2Life
Back2Life Member Posts: 2
edited April 2021 in THE MAIN WALL
This is my first post, hello all.
I have a steam boiler and the pilot light keeps turning off. I changed the thermal coupling twice and I'm still having the same issues.
Anyone know a solution?
    mattmia2 Member Posts: 13,433
    Is the pilot burner enveloping the tip of the thermocouple? some pictures of the controls would help us figure out what type of gas control chain it has.
    HVACNUT Member Posts: 6,849
    Three times a charm?
    Can you explain the issues? The pilot does light and stays lit, or it doesn't light at all?
    What make and model boiler?
  • Back2Life
    It is enveloping the tip of the thermocouple. Hopefully these photos help
    The pilot lights and stays lit only when the boiler is actively running. I have to light it every time I want it on.
    So the thermocouple holds the safety valve open when the main burner is firing but not with the pilot burner?
  • JUGHNE
    JUGHNE Member Posts: 11,453
    Is there a flue damper on the exhaust pipe of the boiler?....it looks like there might be.
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,409
    Could be a bad gas valve. Or something causing pilot to blow out.
  • clammy
    clammy Member Posts: 3,228
    Check where the pilot tube attaches to the pilot light assembly which also holds the thermocouple . Some times when changing the thermocouple one neglects to make sure that the compression nut is tight . It can be a call back and some times some thing even a seasoned vet could miss it’s sure some thing to check and also possibly the orifice . Peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
