Thermostat change in triangle tube HL-45 tank
erikeman13
Member Posts: 9
Hi was wondering if anyone hade any info on changing out the thermostat in my 1999 triangle tube phase 3 hL-45 storage tank. I received the replacement and it has 2 prongs and the instructions say if you have 3 prongs to disregard the 3 wire (green) and just use the brown and black. Problem is mine has 4 wires so wants sure how to proceed. The guy at the company said my storage tank only needs 2 wires. I found the thermostat that’s in there online but it was only available in the UK and off of a coffee machine website. Any help would be appreciated very much. I attached some pics.
You should only need 2 wires. Trace your wires and see where they go. If brown and black go to the boiler or pump relay like to terminals T T you should be ok. It would be better to get a cheap test meter and check it out. Basically when the thermostat calls for heat the contacts close and it should start the boiler or circulator or zone valve.
Why are you replacing it? Have you proven the system will work with the control bypassed? You could have another issue0
- 116 Geothermal
- 169 Indoor-Air Quality
