TACO 007E
My TACO 007-F5 circulator pump burned out that goes to my SuperStor. I bought a new TACO 007E to replace it. It comes with a small white IFC check valve. My old style did not have one. Do I install it with the new pump? I don't see a check valve anywhere in the system.
  • Dave H_2
    Dave H_2 Member Posts: 622
    There are a few "it depends"
    It depends upon the rest of your system and also how it is piped and controlled.
    A picture of the system (stand back a bit so we can see the pipes and where they go) helps alot.
    The 007-F5 could get a check valve, it needed to ordered that way. The 007e comes with it now whether you need it or not. We wanted to make sure you have it and not need it then not have it and need it!
    Dave Holdorf
    Taco, Inc
    EBEBRATT-Ed Member Posts: 20,172
    If you didn't have it in the old pump and everything worked ok then you shouldn't need it now
    EdTheHeaterMan Member Posts: 12,179
    edited March 2021
    Agree with @EBEBRATT-Ed, but don't throw it away. If you have 2 or more pumps on the system there may be Flow Control Valves installed to prevent a zone pump or DHW pump from pushing heated water backward thru zones that are not calling. If that is the case, adding a second check valve may cause problems or noise when the water between the 2 check valves expands or contracts as the temperature changes when everything shuts down. There may even be enough expansion or contraction of the water to create a hydraulic pressure or suction "lock" that a pump will not be able to overcome to open the closed valve. I have been on one such service call. Try to figure that one out?
    Ask me if you are curious.
    Mr.Ed
