2 line system for 2 furnaces
Dukeofoil
Member Posts: 1
in Oil Heating
Can anyone help with a diagram of how a dual furnace system with return lines should be plumbed. Check valve location...
I assume you mean hydronic boiler? Primary-secondary or with a hydraulic isolator is by far the best way to do it.0
- 120 Geothermal
