Indirect tank with coil at top?
Ahead
Member Posts: 11
Continuing my research on utilizing an electric water heater tank for both area heating and DHW... (NOTE: Please accept this as THE solution; I don't wish to get into all the details as to my reasons for this "choice"- I am just looking to see how this solution could be implemented).
Is there an indirect tank with electric heating element (usually referred to as backup) with a single coil/exchanger that's at the top of the tank?
I need to pull heat OUT of the tank, in which case I need to pull from the top of the tank. All tanks that I can find have coils/exchangers at the bottom of the tank.
I suppose that if I have to I can look to utilize a standard electric heater tank and run recirc loops to plate heat exchangers for each heating need (one for DHW and one for area heating): at one point I was set on doing this for the DHW to avoid storing potable water; I can, however, take it or leave it. Don't know, however, how I'd plumb the ins and outs of the tank: whether I could Tee ins and outs to serve both exchanger loops; pretty sure that check valves and such would be important.
Get a custom tank. I think Vaughn may do that.0
https://www.vaughncorp.com/downloads/catalogs/solarbrochure.pdf
Check out Vaughn solar tanks. I think they start at 65 gallons. Maybe they can build a 50 gallon tank for you.1 -
Thanks, folks. I'd spotted Vaughn, but was concerned about the hydrastone lined tank, shipping costs. Their 2-coil unit (top and bottom) might be the ticket (I wouldn't use the lower one). I've sent them an inquiry as to whether utilizing a 6kW element would be OK (their specs say wiring is good for it).
I'm actually leaning toward an 80 gallon tank, so sizing here is fine.0 -
Heat Flo solar tank with two coils.0
If you're not in a hurry you may save on shipping cost by having the tank shipped to your local distributor with the distributors normal delivery.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
