Second Floor Much Warmer Than First FLoor.
Vent Rite #1 can be totally shut off acccording to Gill/Pajek report. I don't know how true it is in practice.0
There is a point at which more venting capacity has no effect. It becomes like an open pipe.
@dabrakeman Do you know how much difference there would be if you had only 1 Gorton#2 on line? That's what I ended up with for my similar main.0 -
In a moment of insanity, I calculated the pressure to lift a ping pong ball sitting on top of a NoM vent orifice. See the chart and calculations. If nothing else, it gives a perspective on weight vs. pressure for different openings.
@SteamingatMohawk
I will have to add that to my to do list since I originally added the second Gorton 6 years ago back when my vents were located back at the boiler instead of end of mains, and there were other circumstances confounding. What I do know right now is that with a cold system and cold pipes the time from steam getting to my header to the end of the main is less than 2 minutes.0 -
40ft main0
- 87K THE MAIN WALL
- 58 Biomass
- 112 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
