Tuttle and Bailey radiator
willy00
Member Posts: 4
in Gas Heating
Hi,
My old house has old T&B radiators and one of them is leaking water. My contractor said he has ever seen this type of radiator. If you have any idea about the location I can purchase the same one or anything alternatives which doesn't require piping works, would you mind letting me know?
I am in MA.
Thank you!
I am in MA.
Thank you!
Thank you for your response. Here it is.0 -
Here is with the cover. I look forward to hearing from your comments.0 -
If your contractor has never seen one of those, he has very little experience in homes built in the early to mid-1950s. They are all over Massachusetts, but that style was not popular in residential construction for very long.
It is rare for those to leak. It may be possible to solder the leak, or take it to an automobile radiator shop for repair.
They are still manufactured, though they are mostly used in commercial construction today. The technical term is “cabinet convector”.
There are several manufacturers. Here is one:
https://www.sterlingheat.com/convectors—
Bburd1 -
Oh thank you so much!!! Honestly, I was concerned about paying huge amount of $$ to replace the entire pipes and radiator etc. I will search around if there is anyone who can repair this. I really appreciate your sharing comments.0
I'm renovating an old farmhouse and have some of several sizes, that appear to be like the one you pictured. Let me know if interested.0
If the coil is leaking you can have a coil manufacturer make it for you if you cant find an exact replacement. I'm assuming you don't want to disturb the cabinet and do any carpentry. and if you want to get creative you can assemble two rows of baseboard front to back. bullhead tees on supply and return.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
