Outside Air Setpoints question
My thermostat has a screen titled "Outdoor Air Setpoints" It includes the following:
Outdoor Temp :
OA HTG SETPT:
OA HTG ENABLE: (Yes or Not)
OA CLG SETPT:
OA CLG ENABLE: (Yes or No)
What are Outside Air Setpoints and how would these settings affect the run/output of the AHU. What are the benefits to enable or disable these settings? Are there preferred settings for these setpoints?
Thanks very much for your help.
djwalk
    EBEBRATT-Ed Member Posts: 20,039
    We would need to know the Make and model of the thermostat and if you have an outdoor sensor wired to the system
  • djwalk
    djwalk Member Posts: 2
    The thermostat is a Reliable Controls Mach-stat. Yes, an outdoor sensor is wired to the system.
    Thanks very much.
