Utica furance from 2001
solarconvert
solarconvert Member Posts: 16
hello - we have a furance that was installed new in 2001, the Utica model number 5FH-4150. We’d like to know if the unit was built with any asbestos in it. I was wondering if by 2001 there were regulations banning the use of asbestos in residential units. thanks in advance for any info you can provide.
    Steamhead Member Posts: 18,501
    Nope. They have fiberglass insulation.
    Is there an issue with this boiler?
    Consulting
    solarconvert
  • solarconvert
    thanks, for the quick response Steamhead. I’ve seen fiberglass between the cast iron and the sheet metal housing. Is the material in the combustion chamber fiberglass, too? really appreciate it.
    It's Kaowool, not asbestos.
    Consulting
    solarconvert
    EBEBRATT-Ed Member Posts: 20,187
    @Steamhead
    Guessing by his name and the question the op is going to yank it and go solar :)
    solarconvert
  • solarconvert
    thanks all - yes, the system has been decommissioned.
  • solarconvert
    while we’re on the subject of insulation materials, any idea what this spongee stuff is? it is a very old patch - maybe from the 50’s?
  • unclejohn
    unclejohn Member Posts: 1,833
    That may very well be asbestos. Wet it down a little and take a sample to some place that does removal and they will tell you for sure.
    solarconvert
    Depends when they patched it. Pre 1980ish it could be asbestos
    solarconvert
